Indirect w/ gas water heater as storage/backup
Anyway of utilizing an indirect water heater for domestic hot water production, with a natural gas water heater being used as a storage tank and back up when power outage may occur?
Any links for piping diagram would be great.
  • Ironman
    Ironman Member Posts: 7,927
    Sure. Simply pipe the gas heater in series, downstream of the indirect. Leave it's thermostat turned down somewhat lower than the indirect's until you need it to fire.
    If you're on well water, well, you won't have any water when the power goes off. But you realized that, I'm sure.
    Bob Boan
  • Bug512
    Bug512 Member Posts: 52
    How often do you loose power ?
    Gene in Northern NJ
    NJ HVACR License 19HC00537600
