Danfoss TRV with Street elbow..ok?
Spunky424
Member Posts: 82
So i have minimal clearance on the end of my radiator where the vent is installed. i already have the danfoss TRVs but the clearance is just too tight to make it work. would it be okay to have a 1/8" street elbow installed and then the danfoss TRV Body and actuator attached to it? thanks in advance.
Will you even be able to screw it in if you do that? Another possible problem would be that would place the TRV very close to the radiator which would likely influence the setting on the TRV. Are you using a remote sensor or one mounted directly to the body?
Are you just talking about making it face outwards toward the front of the radiator instead of sticking out the side? If that is the case there should not be a problem.0
yes that was my ideaRobG said:Are you just talking about making it face outwards toward the front of the radiator instead of sticking out the side? If that is the case there should not be a problem.
i'm using the remote sensor but i do have to check the clearance i hope itll fit. if it doesnt. is there really any other option? my radiators are recessed into the wall underneath my windows.KC_Jones said:Will you even be able to screw it in if you do that? Another possible problem would be that would place the TRV very close to the radiator which would likely influence the setting on the TRV. Are you using a remote sensor or one mounted directly to the body?
With the remote sensor it shouldn't be a problem at all as long as you have room to screw it all together. Pay attention to how you position the elbow, make sure you don't slope the TRV away from the radiator. Other than that I can't think of any problems with this.0
I would also suggest you put a small amount of insulation on any additional piping to aid in responsiveness.0
sometimes a TRV is chosen for a system to solve a problem caused by an unbalanced system, caused by a lack of venting.
have you checked that?--NBC0 -
If you're going to install a TRV via an elbow I would, even though it's gonna look worse, make sure it's pitched back towards the radiator.
You need to ensure any water that finds it's way in there can get back out or it'll give you endless problems.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I'm using trvs since not all the rooms in my house are occupied. There are a few vacant rooms that I would like to keep the temp lower than the rest of the house so they get the bulk of the steam. Not sure if that makes sense.nicholas bonham-carter said:sometimes a TRV is chosen for a system to solve a problem caused by an unbalanced system, caused by a lack of venting.
Just be aware your system will not work well if you throttle the output significantly and it can become inefficient. Steam systems operate best when the output of the boiler match the capacity of the radiators.
3PSI gauge0
- 87.4K THE MAIN WALL
- 15.8K Strictly Steam
