Buderus G215/3
Hilly
Member Posts: 429
With the way this boiler mixes supply and return water it states that 122*F Supply is enough and return waters are not an issue if the 122 can be reached in 10 minutes of firing. My real question is, would the design of this boiler mean that Primary loop piping systems are not of much benifit?
That would also depend upon your system and it's flow requirements, but in most usual cases p/s is not necessary.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 120 Geothermal
- 169 Indoor-Air Quality
