Sizing boiler for remodeling.
Thinking
Member Posts: 3
Planning new radiant heating system on the ground floor for our home. The house was built in 2005 by US Homes. Our house has forced warm air on both floors, two separate systems. My question is for the first floor, for radiant heating could I use the size of the furnace for the sizing of the boiler for radiant heating?
In a word, no. Someone needs to perform a room-by-room heat loss on the structure. Where are you located?0
Do you have the heat loss calculation from the original system?0
Yes, we are putting hardwood floors in two rooms that were carpeted. I didn't think the manual j changed btus when selecting heating type.0
So,here is the part you are missing. I guarantee no one from US Homes ever did a heat loss. Even if they did, the furnace was likely just rounded up to the next size in whatever brand was giving them the best price.
It takes so little time to do a heat loss, why not just do one?
Over sizing boilers and circulators is a huge waste of energy.
Albert Einstein2 -
NEVER , I repeat NEVER did US Homes or Lennar or Centex , K Hovnanian, Pulte perform a PROPER heat loss calculation for any home they ever built save for a rule of thumb number . Bigger is better and if it aint well , too bad . Was , is and will continue to be the norm . Even their energy star homes are piss poor excuses for something called energy star . Where are you located ? I suggest using the find a contractor feature and locating someone relatively close to you to assist . Maybe even myself if you are in Jersey . Hell , we were one of the largest markets in the country through the 80's into 2000s . Ocean and Monmouth county especially .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Plus, a radiant heat loss calc will have different values than a Man J. Usually lower, and possible supplemental heat needs are revealed, floor loading, etc etc.0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
