Tankless water heaters
Steve_210
Member Posts: 664
I have a AO smith cyclone BTH 199 that I need to replace, not thet it cannot be done but it is a major project to get that one and get the new one in because of where it is located, and things that Have been done since it was installed.
Therefore looking at a tankless I downloaded the Bosch sizing app.it is gives me the C 1210 ES.
I always have the option of putting a second one in later if demand is not enough but I have checked it three times.
Has anybody used these Bosch I have not used any so far, The tappings are only three quarter-inch Just a little concerned it can give you the hot water it's it claims to,
Any advice Greatly appreciated.
Bump0
Tanks can give a abundance of flow depending on pipe, pressure and friction of system. A quality tankless can deliver a steady stream of consistent water at a preset temp, limited to its BTU fire capacity and temperature rise required.
To replace a BTH199, it will typically take 3-4 199K tankless to meet the peak GPM that a tank of that size may see. Bearing in mind a tank with a large draw requires recovery time to bring temp back up or it will deliver less than setpoint temp.
BTU for BTU replacement is not the way to go with tankless, nor is gallons per hour, like a tank is rated. Its always PEAK GPM REQUIRED for tankless0 -
Okay I'm now looking at a bosch C1210 ESC with an AO Smith TJV 80 gallon storage tank.
Really appreciate you earlier help I would just go to BGH 199 but with the weight it is very hard to get in there0 -
Your earlier help and BTH 199, sorry I could not seem to edit that last post0
Do need a heater that big.
What is the application and usage?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Thanks guys it is a restaurant to be safe I need 230 gallons per hour0
A tankless can give you 230 gallons per hour perhaps, that's only 3.84 gallons per minute. But what it cant do is give you 10 gallons per minute when multiple fixtures are drawing.Steve said:Thanks guys it is a restaurant to be safe I need 230 gallons per hour
That's the difference between tanks and tankless, not being able to compare BTU's. That's why I said the tankless replacement for the tank could be three tankless units, but a proper sizing is required.
Restaurants are a different game. This will vary from state to state.
Where I am (Colorado), the state health department has a specific calculation that has to be done to assure that the hot water needed to sanitize is always available.
Tank vs Tankless is a different formula.
If you made the swap you are suggesting here,without doing the calcs and getting approval, you would fail your next health department inspection.
Look into your local regulations to be sure your Butt is covered.
Albert Einstein0 -
Thanks guys I think I'm going to just stick with replacing what's there.
Is the only way to be safe0 -
100/199's are not at all cheap if you replace them as regularly as many users do. If they're using two or three of them, a high capacity 119 gallon indirect with a 399 mod/con will easily outperform and outlast the commodity tanks.0
Or a modcon with a reverse indirect If continuous flow is needed.0
Thanks again guys great advice will keep in mind for the next one0
I've seen many many restaurants done with tankless alone as well as tankless/storage. I seldom recommend a single tankless regardless of how small and light the places hot water requirements are. It is a commercial establishment and redundancy is very valuable. Typically the sizing is done on tankless with storage and without. Properly sized and laid out they are excellent systems.0
Yes very much appreciated guys, it is wonderful that we can come to a place like heating help And get this sort of advice thanks again.
None of us will ever know everything so hopefully we can all help each other out.0 -
If you can at all get a tank type in there , try one of the Sanitizers . http://www.htproducts.com/literature/lp-191i.pdf
If you have a need to go tankless , there is a whole new breed ,
http://www.htproducts.com/hydrasmart-commercial.html or
http://www.htproducts.com/hydrasmart.html . Yeah , HTP making better stuff again . I am interested in your thoughts on these Carl , Rob and Kurt and whoever I forgot .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
I went with a tankless And 80 Gallon storage tank
Everything working great.0 -
Rich I will save your links your tankless looks very interesting0
Rich, It looks like a nice unit(s) and I would like to try one in a system where I could size it for the application. The problem that I see would be the price point. Most homeowners and business owners would not pay for the higher quality if a Rinnai will give them the same GPM, they would rather spend the $$$ on a BMW. The other problem is availability for restaurant / hotel retrofits. When their water heaters go out it's a mad scramble to try and find a replacement, yesterday!
Have you installed many? How are they in comparison to other brands?0 -
Always the price point . Why is it that everyone thinks HTP stuff is more expensive than other equipment when in all actuality this is not the case . What are the odds that all 3 or 4 burners and HXs take a dump simultaneously ? Pretty low I would imagine . Kinda gives the owner a sense of security along with the fact that these are not your average Rinnai , Navien , HXs . You did notice that these are redundant units and cascaded did you not Rob ? Me thinks any job that would require multiple units or had a space issue and a large demand these would be the ticket . If they cost a bit more how much could you save only plumbing 1 unit as opposed to 3 - 4 ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
No, have not installed one yet . Quite honestly you'd need a hell of a demand to require one of these and I probably as always would search for a reason not to use a tankless . That being said if I had to use a tankless there would be no need for me to look to another manufacturer than the folks in Mass . I have installed the residential Hydra Smart and can honestly say it outperforms anything else we've installed prior . I was at HTP in October and did lay eyes on these units and along with the new EFTC-140F combi . These guys are not BSing in the engineering department , these are guys like us building stuff that we would build , not mechanical engineers listening to a marketing departments , bean counters and DOEYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich, I am speaking primarily of the residential when I am talking price. The availability is the issue when it comes to all of the units. I called my rep and found that no one even stocks the product in my neck of the woods. I would love to do a job that the engineer specified the product (that's the reps job, not mine) and I had the opportunity to order it in, but as it is, if it's not available, it's not getting sold.0
