Maintaining System Pressure
Ironman
Ironman Member Posts: 7,857
I found this photo over at ElectricalContractor.net. I'm not sure but it appears that someone rigged a bug sprayer to pressurize the hydronic system.
<a href="http://www.electrical-photos.com/showphoto.php/photo/1027/title/boiler-control/cat/500">http://www.electrical-photos.com/showphoto.php/photo/1027/title/boiler-control/cat/500</a>
Bob Boan
  • icesailor
    icesailor Member Posts: 7,260
    System Pressure:
    Must have been reading some DIY heating site.
    I'm particularly impressed with that R-19 foil insulation covering the pipes. If it's that important to need to use a bug sprayer to maintain pressure, I'd hate to have to look for a leak.
    A cheap out if you want to maintain pressure with Anti-Freeze in a system. A lot cheaper than using a Well Extrol tank, pumped up with solution and connecting it to a boiler drain before the fill valve.
    Steamhead is Wrong. You CAN fix stupid. There's an example of it.
