Hot water Run for heating
Vijay
Member Posts: 1
In one class, I remember having learnt that hot water run on wall radiators shouldn't be more than 70 feet. Even if booster pumps are placed - there is not enough energy to travel.
May it be confirmed please.
Not that simple
It could be that if a designer prefers a certain circulator, specific pipe size and a set number of emitters on a loop that it works out that 70' is the max.
In reality it really depends on the individual system. There is no magic maximum number. It just depends on the requirements of the emitter and the pipe size and circulator being used."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 62 Biomass
- 114 Geothermal
