EDR For Radiant Radiator
Yasar
Yasar Member Posts: 4
Hi Guys,
I have a radiant radiator (please see attached). I just want to know how I can calculate the EDR for this. There is nothing written on this so I can't tell you what type/company this belongs to.
  • SWEI
    SWEI Member Posts: 7,342
    Measurements?
    Looks a lot like a Myson Selecthttp://www.mysoncomfort.com/Radiators/Select
  • Ironman
    Ironman Member Posts: 7,918
    Panel Rad
    It would get a lot more btu output if it was mounted on the wall like it's supposed to be so air could enter thru the bottom.
    Bob Boan
  • Yasar
    Measurements
    This height is approx 27 inches and Width is 31 inches.
  • Yasar
    Wall mounting
    I have checked this from the back as well and it do not have wall mounting brackets etc. Any suggestion how to mount this on wall as this thing weights more then 30kgs
  • Ironman
    edited September 2014
    Wall Mounting
    The brackets came with the rad.
    I would check with a Myson distributor and have them order a set. There also may be a floor mount kit available that would hold it up off the floor so air could be drawn into it.
    Bob Boan
