Condensate Return Line Cleanout System: looking for recommendations
KevinK
Member Posts: 67
System details: one pipe steam; residential; 150,000 btu boiler.
My 85 year old iron condensate return lines had to be replaced due to corrosion and sediment build-up. This was done 4 years ago; the new lines are copper. I am wondering whether I should add a cleanout system. I am looking for nput/recommendations.
The CR lines consist of two legs of approximately 50 ft each. I am assuming that I would need something like a ball valve at each elbow where the CR vertical drop “elbows” to horizontal. (Maybe on a wye on the drop?) And then another ball valve at the cleanout where the CR line meets the near-boiler plumbing. If I had garden hose fittings at each of these three locations, I could use a garden hose, first from one side and then the other, to wash out the sediment. The discharge could be conveyed to my basement floor drain via a second garden hose. If I did this once per year, I’m thinking that I could maintain clean CR lines for generations. So, my basic questions are:
1. Is a CR cleanout system recommended?
2. Is there a standard approach to this/what are the recommended “details?” E.g., type and location of inlet and outlet valves; mechanism for conveying the discharge to floor drain.
3. Are there issues that I haven’t thought of or am unaware of? I am asking this in part because it seems like such a no-brainer, and yet I haven’t seen this mentioned anywhere.
Thanks.
Thanks.
One-pipe steam. NG fired. 2100 sq ft heated space.
Utica Boiler PEG150C (150,000 Btu/hr Input) connected to 491 sq ft of radiation. Operating press 0.5 psi.
A cleanout arrangement
is a good idea -- although you may find that once a year is more than enough. Surprising how clean steam is...
If it were mine to play with, though, I'd have a ball valve where the lines meet the boiler piping, so you could isolate the boiler from the returns (not a bad idea anyway -- that way, with a king valve on the connection from the header to the house system you can completely isolate the boiler if you even need to raise the pressure on it slightly). But I wouldn't bother with big valves on the rest of the return system -- they're expensive. Instead, have drain cocks (you need them anyway) and use T's with a threaded plug. Just close the main valve, open the drain cocks, undo the plugs and blast away with your hose...Br. Jamie, osb
Thanks for your input. The CR lines are 1-1/4” copper. Through my local htg equip supplier, I found the Webstone 3-way ball valve that has a capped hose connection:
http://www.webstonevalves.com/default.aspx?page=item+detail&itemcode=50614W&catlist=24
I plan to install these on the two CR drops.One-pipe steam. NG fired. 2100 sq ft heated space.
Utica Boiler PEG150C (150,000 Btu/hr Input) connected to 491 sq ft of radiation. Operating press 0.5 psi.0 -
Ball Drains rock
One of our favorite fittings. Buy them by the box.0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
