Electric Boiler and short cycling
Hilly
Hilly Member Posts: 429
Is Short Cycling a big issue with an electric considering it is nearly 100% efficient? I know components will suffer shorter life expectancies but is that the only concern? Am I wrong that short cycling concerns are mainly an efficiency concern?
  • SWEI
    SWEI Member Posts: 7,348
    edited August 2014
    Efficiency and comfort
    What kind of controls are on the system?  If it's a bang/bang thermostat, you will get greater temperature swings than you would with PWM -- even for a single element.  How big is the boiler?  For smaller sizes, you can use a line voltage thermostat directly, but adding a contactor for larger elements (up to a point) is not very expensive.
  • Zman
    Zman Member Posts: 7,611
    Demand Meter
    In addition to SWEI's response,
    On premises that are "Demand Metered", is is a good idea to have multiple elements and stage them. Bang Bang thermostats with leave you with very high demand spikes which will raise your rates.
    Albert Einstein
    hot_rod Member Posts: 25,327
    older style
    electric boilers had magnetic contactors, frequent, short cycling wasn't kind to those contactors. Plus the noise and lights dimming :)
    Most of the current electric boilers have triacs controlling them, for variable outputs and soft starts. Triacs, electronic relays, are very rugged devices.
  • SWEI
    Right, and for older units
    you can use a line voltage PWM stat (which has its ownTRIAC) to trigger a zero-crossing solid state relay for larger loads.  You can also phase chop (dim) them with 0-10V control signals for full modulation (at the cost of some increase in line noise.)  Works well with ODR controls.
