gorton valve
alliance
Member Posts: 3
i have a steam boiler, when the heat goings on all radiators in the house are fine. when the heat goes off and radiators start to cool, 1 radiator makes this loud sucking noise. what can be done to stop this or what could be causing this?
Radiator Vent noise?
Is that radiator the first or last radiator on that main? Have you tried switching out the vent to see if that changes anything? If it's the first vent to open after the boiler shuts down there will be a small vacuum in the system as the steam condenses and if that is the first vent to open, it may be the only one that breaks that vacuum and sucking all the air in until others open. Are you sure your main vents are working ?0 -
What model air vents
do you have on the radiators and steam mains?
It's normal for a vacuum to form when the system shuts down but having large enough main vents could help.
3PSI gauge0 -
radiators that suck
Did you ever solve your problem.
It can be solvedSince 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930
- 120 Geothermal
- 394 Solar
