Controlling feed rate for skimming
The Gel
The Gel Member Posts: 3
A really basic question about skimming.  I understand that I'm supposed to replace the water at a trickle as I skim.  I can see how that would be fairly easy.  Unfortunately, I don't have any sort of manual bypass; just a McDonnell Miller 101 A sitting in the middle of the feed pipe.  Any good ways to keep a slow feed going?
  • Paul48
    Paul48 Member Posts: 4,469
    Boiler Drain?
    Jamie Hall Member Posts: 26,842
    Hadn't thought of that!
    Neat idea.  Perhaps you could create a hose with female couplings on both ends, hook one end to a boiler drain (if you have one!) and the other to a convenient hose outlet?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,364
    Push the .....
    ...Red button on the 101 to manually feed water into the boiler......
  • Paul48
    Amazon
    Female x female hose adapter
