Janitrol Automatic pilot
DPeak
DPeak Member Posts: 3
Our very old hot water system has a pilot control made by Janitrol/Surface Combustion. It sends an electrical signal to a controller that opens the gas valve. The type designation is X O. It has apparently died, as bypassing it allows the boiler to fire. See picture attached.
Anybody know if there is a modern replacement part available? Or if there are any originals floating around?
  • Ironman
    Ironman Member Posts: 7,927
    Pilot
    You should move this over to the"Gas Heating" forum and post it there. If anyone knows the answer to your question, it would be Tim McElwain.
    Bob Boan
