Steam release
Joe Mattiello
Member Posts: 748
Radiator spewed rusty water all over the wall, and fllor; why??
Steam pressure?
Steam pressure?
Joe Mattiello
Taco Comfort Solutions
Could be any one of a number of things...
excess pressure is one.
A closed or partly closed inlet valve to the radiator.
A bad vent.
Just for starters...Br. Jamie, osb
Sudden radiator "accident"
Has the system been serviced regularly? In particular, the pressure should be checked, as well as cleaning the pigtail under the pressuretrol. Other causes may be blocked main vents, due to dirty water.
Something must have changed recently unless this is a regular occurrence.--NBC0 -
I'm going...
to vote for dirty system water fouling the vent.0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
