ECR 97GB / Utica SSC Heat Exchanger
Ironman
Member Posts: 7,859
Sometime back, there was a discussion as to whether the heat exchanger in these boilers was indeed self cleaning or whether the fins would foul like some copper fin tube boilers did.
They say a picture is worth a thousand words. This pic comes from one that I installed three years ago and just serviced. It's main load is a large in slab radiant floor which means it's probably condensing at least 90% or more of the time which is when deposits are formed. Judge for yourselves.
Bob Boan
Is that bad or good
I'm not a heating professional but I love the trade. Is that bad or good?0 -
Good
If that picture of the HE is without being cleaned in three years and with the boiler in condensing mode it sounds like it is living up to its claims (however I would not want to see any condensing boiler not serviced much longer than that). Pretty impressive.
Rob0 -
between the loops
Was there any build up between the loops? How do you clean something like this? --it looks like most of the heat exchanger surface is inaccessible.0 -
No Cleaning
I only cleaned the burner. The white blotches are pieces of gasket material the fell off while removing the burner.A soft brush should work for cleaning the fins, though, they're pretty sturdy being stainless steel.
Sorry about the rotated pic. I think the site does it for some reason.
Here are a couple more:Bob Boan
Utica SSC Boilers
Their ad says "The only homegrown, low maintenance Stainless Steel condensing heat exchanger designed in the USA for the USA". I love these boilers, chalk one up for the "Buy American Crowd"!
Thanks, Bob GagnonTo learn more about this professional, click here to visit their ad in Find A Contractor.0
