Steam Radiator
ssmh
ssmh Member Posts: 8
We have a steam radiator which is only heating on the supply vavle side. Any suggestions how to proceed next?
Jeff
    Jamie Hall Member Posts: 26,835
    Need a lot more info...
    is this on a short run?  Long run?  Are other radiators hot all the way across?  Valve fully open?  Condition of trap (if any)?
    Presumably two pipe, since you reference "supply valve side"?
  • ssmh
    Steam Radiator/More Info
    Jamie, we have a Weil-Mclain LGB-8; series 2, 910,00 Btu input steam boiler with a Hoffman differential loop, #15 Hoffman vacuum valve & a series 61 low water cut-off. It is a short run, the radiators on the way are hot, the valve appears fully open and we have not investigated the trap yet. It is a two-pipe system.
