Triangle Tube
Zman
Member Posts: 7,614
I am working on a Triangle Tube setup that is about 6 years old.
It is a MCBA3 controller with a AM3 mixing controller wired directly to it wired via ribbon cable.
The system worked perfectly for 5 1/2 years until a local heating company did a service and reset it to factory defaults.
I have the original paperwork on the mixing controller and have set it up as directed. I contacted the original installer who has since moved, He indicated that there was another parameter that tech support advised him to change that is not in the manual.
So far tech support has not been helpful (they cannot find the manual I have) I am expecting a call from a senior tech today.
Does anyone have experience with setup?
Thanks,
Carl
Thanks,
Carl
Albert Einstein
Albert Einstein
