Can I Adjust My Pressuretrol?
dubbsi
dubbsi Member Posts: 18
Hi Everyone,
First, I want to say how grateful I am to have this resource online. My wife and bought an 85-year-old house this past spring with one-pipe steam heating, and it's currently in the midst of its first New England winter with us as the homeowners.
I bought "We Got Steam Heat" and plowed through it earlier this week, so I have a small grasp of what we're dealing with, but there are a number of issues with our heating system, so I suspect I will be posting on the wall every so often.
Anyway, my question regards my pressuretrol (pictured). It's currently set at 3psi (main) and 1.25 (diff). I know I should lower the pressure. However, on the plastic covering, there is a sticker with this note: "The Main Scaleplate has an installed safety stop. DO NOT ALTER." Can I remove the plastic cover and lower the main pressure to 1.5 psi, or will that turn off the boiler? We're about to go into a deep freeze for a couple of days, so I don't want to accidentally turn off the heat.
Thanks in advance.
  • Mark N
    Mark N Member Posts: 1,144
    edited January 2014
    Pressuretrol
    There are 2 adjusting screws on top of the pressuretrol. One for the main the other for the differential. That looks to be the same pressuretrol that is on my Burnham IN-4. I have mine set to main=1, and diff=0.5
  • dubbsi
    Well, I'm a dope
    Thanks, Mark, for that quick and easy solution! I'll definitely never have to ask that question again.
  • Mark N
    Glad to Help
    Your welcome. Everyone is a beginner at some time. Pick up "The Lost Art of Steam Heat" if your interested in how it all works. If you're so inclined lots of good info under the Resources tab in the Library and under the Systems tab under Steam.
    Jamie Hall Member Posts: 26,838
    And just to add to your confidence
    the installed safety stop is to limit the maximum pressure you can set the pressuretrol to, not the minimum!
