Thermostat set backs with Vacuum Vapor System
Steve_55
Member Posts: 30
Have a nearly 5,000 sq ft home with a well maintained, Vacuum
Vapor System, fired by a newer Peerless
EC ECT Boiler and an efficient Reillo Burner
Also have a Lux Thermostat with Swing Temperature currently set at plus/minus
one degree
Today fires twice at day – once in the morning for 3
or 4 hours (at 1.4 gph) and once in the later after noon.
Works well but has a temperature variations between
firings during the day (in the evening too, but that is OK).
Question would setting back the swing temperature to,
say, plus/minus ½ degree be a good idea – probably more even temperatures
during the day but a $4.00 a gallon do we burn a lot more oil?
one degree
Probably not
although one can't guarantee anything. But there is a sort of general feeling that one uses more oil bring the temperature up a degree or two (never mind deep setbacks!) rather than holding a more constant temperature.Br. Jamie, osb
My System
Is you system cycling with the pressuretrol / vaporstat, or is it running continuously for 3 - 4 hours?0 -
it runs ....
... continuously for 3 - 4 hours (typically close to 3 hours)0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
