Cold spot ?
Danscrew
Member Posts: 130
I have a cold spot in my Basement Bathroom. Tiled to ceiling 6L x 4W 6'.7" ceiling. I have a 24" piece of fintube baseboard and its not enough I was thinking of those Myson Radiators? in place of the baseboard I only have 24" to work with. Also I am woking off a reset so at 32 degrees I am making around 131 degree water seems like its to cool to get any heat out of a 24 inch piece of fin tube? whats the cutoff or minium where you dont get anything out of it? its speced at 600 BTU'S at 180 degree water I am no where close to that Looking for any ideas Thanks Dan
Panel radiation
Panel radiation is best option with small space and low water temp, performs extremely well
If you can find areas that need air sealing that is my first choice for adding comfort to any space, then you really reduce load neededThere was an error rendering this rich post.
Towel Warmer
You need to find out the heat loss for the space then size the heater to the heat loss at you water temp.
It sounds like you have limited space, would a towel warmer work?
Albert Einstein0 -
Easy fix
would be Smiths Heating Edge baseboard , @ 130* depending on which way you pipe it (there are choices) you can get anywhere from 349 - 516 BTU per foot . Although your boiler is making 131* water at 32*F depending on where this piece of heat is situated in the loop I would imagine a lower temp at that location . I would go with a lower temp through that piece of baseboard to achieve comfort in the bathroom , a towel warmer is a good idea also as stated .
http://www.emersonswan.com/ckfinder/userfiles/files/High%20Eff%20%20Guide(1).pdfYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
