Still no heat after replacing Taco Pump
We have a System 2000 I think EF-1 that really needs some work. We recently replaced the Honeywell R8184G relay and now since no heat our circulator pump went. Today we just replaced the pump with a brand new one and STILL NO HEAT. Is there something we missed ?
  • Zman
    Zman Member Posts: 7,611
    Troubleshooting
    Do you have and know how to use a voltage meter?
    You need to narrow down the problem rather than replacing parts.
    The first thing most technicians would do is determine whether the circulator is getting power.
    Albert Einstein
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    Yes...
    Troubleshooting and diagnosing HVAC systems involves a very specific sequence of steps and having a thorough understanding of how these systems operate is key. Along the lines of what Zman said, replacing parts is expensive and frustrating. Prove that a part has failed before replacing it. By providing symptoms, we may be able to help in that process.
    Steve Minnich
  • bustoff315
    bustoff315 Member Posts: 26
    No heat?
    How did you come to the conclusion the circulator pump was bad? Is there isolation valves or did you have to drain the zone?
