Waste Oil Heater
Techman
Techman Member Posts: 2,143
What is the btu content of motor oil/tranny fluid/rear end fluid? I was told the btu of motor oil is the same as #2 oil .
    Jamie Hall Member Posts: 27,582
    Close enough
    anyway, for most purposes (there are slight differences).  To watch out for, though:
    Some hydraulic and automatic transmission fluids are not petroleum based, and will have very different properties (some are, indeed, essentially fireproof -- intentionally).  I have no direct facts, but it seems possible to me that some fully synthetic motor oils may also have rather different heating values.
    Another big difference to watch out for is, of course, viscosity, which will affect (sometimes dramatically) the flow rate from a specific nozzle at a specific pressure, leading to potential combustion problems.
    And there is a third, but with the type of oils you are looking at it shouldn't be a problem: flashpoint and volatility characteristics.
    Some lubricants have metallic compounds (usually molybdenum or lithium) added to enhance their properties under high contact pressure -- I know that some rear axle lubricants do.  They might give you problems with ash or coking; I don't know.
  • Techman
    edited December 2013
    Well now,
    that is a lot -a- bit more info than I got from the Reznor girl ! Thanks Jamie! The ash is a yearly cleanup on a yearly routine.
