Help sizing
Dave0176
Member Posts: 1,177
Measured a ladies house today, her boiler went south is rusted and leaking. It's probably a 40-50 year old American Standard atmospheric gas boiler. It's sized at 150000 btu. I measured total EDR at 142.6 sq ft two radiators are removed and will not go back in. So it basically sizes up to a WM EG 30 75,000 does this seem too small, should I put the 100,000 in??? Even with the two rads in place it only comes to 192 sq ft. Not a real big house standard small intercity colonial. ????? What do you guys think??
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......
As long as the system is properly vented and insulated
the EG-30 should work fine, even if they re-install those two radiators (which they should!).All Steamed Up, Inc.
Consulting0 -
Header size
Should I build a 3" drop header for this or will be too large?? I need a drop header anyway as the ceiling is too low.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
x 1.5
Forgot to ask, if I multiply the EDR 142.6 by 1.5 I get 213.9, isn't this how Dan said to size the boiler?? Even still it keeps me in the EG30s range of 198 sq ft steam.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
