Boiler header
Badlarry
Member Posts: 1
I'm in the process of adding 2 more zones to my 1 zone heat. Currently I have 1 circulator pump in line. I am going to remove the pump and add a 3 zone cast iron header. Can I mount the header vertical and have the circulators horizontal or do I need to mount the header horizontal??
Motor Shaft
The motor shaft of the circ must be horizontal. It doesn't matter if it pumps vertically or horizontally.
You achieve this by removing the 4 screws that hold the motor to the pump housing and rotating it 90*, if necessary.Bob Boan
Yes,
you can.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 129 Chimneys & Flues
- 122 Geothermal
