correct me if I'm wrong.
Paul S_3
Member Posts: 1,288
hey everyone correct me if I'm wrong I'm going to post some pics. they are of a steam boiler that a company just replaced. the problem is is that the customer is getting major water hammer throw out the system. the system has the original mains two inch. the only thing changed is the return a few years ago in copper. but they added radiators in the basement about chest high. They tee'd from the wet return up into the radiators?????.... how would steam ever get there? also water is backing out of the boiler and turning on the auto feeder..... the boiler is pipes in two inch and a manufacturer's specifications call for that.... the equalizer is piped in 1 1/2" which is what the manufacturer calls for.thanks Paul s
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
pics
here are some picsASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
more
More picsASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
tee
the copper tee that's going up the wall is going to the radiator that is chest high which is in the basement that is the wet return . The main is above radiators....I believe of the main it supplies the radiator and the condensate drains through that copper pipe. customer says it worked perfectly before Paul sASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Water level
Were you skimming when you took the photo of the gauge glass?
If not I would say you have the boiler way overfilled. Water level should be about half way up the gauge glass when cool.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Say what?
There are radiators piped off the wet return about chest high in the basement? Is this one pipe? I presume they have vents on them then... if it's two pipe, where does the feed pipe come from?
In any event... if those radiators are even close to the water line of the boiler, as soon as the system starts making steam the water is going to back out of the boiler and into those radiators -- which can hold a lot of water. No mystery there.
Those radiators have to be at least 28" in a typical system above the water line of the boiler. They must be fed from the steam main, but if it is a one pipe system that pipe down from the steam main has to continue down to a wet return, and there has to be a vent on the radiator. You can do the same thing on two pipe, in which case both the pipe down from the steam main has to drip to a wet return and the outlet, through a trap, has to vent back up to a dry return and drip to a wet return or, alternatively, you can treat the radiator like a one pipe (yes, you can mix one pipe and two pipe setups if you do it right).
Hard to say off hand where the hammer is coming from; keep in mind that it telegraphs through the pipes. It could be those low radiators, though...Br. Jamie, osb
radiators
Jamie... I did not open the walls yet but I believe these radiators are fed from the steam main overhead... and the main is tee'd into where the radiator valve is and goes into a wet return... this is all one pipe steam.... so basically you was saying before that the dimension A is from the lowest radiator in the basement correct?..... water hammer is definitely coming from a few radiators in the basement.... and they are spitting some ...Chris no I was not skimming the boiler it over fills in middle of cycle...thanks Paul sASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Radiators
Sounds like the condensate is backing up the return into those radiators. You don't need to open the valves for that to happen, do you? I can't see how things are piped.
Either way your water is going somewhere and not returning very fast for some reason. Badly pitched pipes?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Easy
The water hammer's coming from that transition from cast iron fittings to copper close to the ceiling with a reducing bushing holding back lots of water in that horizontal line.
You can't often reduce on horizontal pipe. Only vertical.
You gotta fix that.
The thermal image below shows water being held back by a reducing coupling.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Wow!
I didn't notice that until you pointed it out.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
radiators
so how can I fix this problem the boiler is on blocks that give me about 3 inches.... the previous boiler was on the floor you think that would fix it? Paul sASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
This...
...is what I do ;-)Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
Johnny
use an eccentric coupling....or point it down.... and it's hard selling that to the customer when I worked for years before thanks Paul sASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
That's very true.
However, some times bad things stop being cooperative when you change something else in the system. All boilers make steam at different rates, so if the old one was able to push the trapped condensate through the funnel without creating an issue (it happens), the occupant might not have been made aware there was a deficiency in the piping. Lots of people learn to live with some amount of noise in a steam system. It's not right. It just is.
Good luck.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 981 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
