Water Heater - Boiler question
Bill_110
Member Posts: 52
A friend has an empty house with no hot water being used. Is it better in this case to turn the heat setting way down and leave it on, or put on the gas shutoff and maybe drain the water? I was thnking that even with the gas turned off the tank might rust less if the anode rod was doing it's job, which I guess it would't in a tank filled with air. Right now turning it on isn't an option since all his copper pipe was stolen, but he does plan on replacing it soon with PEX.
Thinking about that led me to wonder why steam boilers don't have an anode rod(s) in them, since they are a similar water heating device? Thanks for you insights .
no pipes
if there is no pipe, what is the water heater heating if it is on?0 -
Water heater no piping
The pipe was connected until being stolen a couple of days ago. Even so I'm not sure why or if my friend should have had it on at all since he hasn't occupied the place for quite a while. When he replaces the pipe he still won't be occupying the place anytime soon, thus my question about what to do with the water heater - gas shutoff and drained, gas shutoff and water left in etc.? (He will have his boiler on a low setting once the water supply is restored)0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 985 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
