radiant heat
Paul S_3
Member Posts: 1,291
Hey everyone when doing a radiant job (staple up) and performing a heat loss calculation do I use a standard heat loss calculator like slant fins heat loss express or is there a calculation specifically for radiant thank you Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
Heat loss
Is heat loss.
That program should work fine."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
radiant
Thank youASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Radiant heat loss
I'd be using a program that's specifically designed for radiant applications like the Uponor ADS or Viega's software. Both will allow "what if's" that show design temps and flow rates for a suspended application with plates or without. Then you can see the difference and design accordingly. The S/F program uses the Manual J calcs. Radiant values are lower and using the S/F program for other than baseboard or radiators will tend to oversize the system.0
- 114 Geothermal
