Facility Manager
Leakcheck
Member Posts: 1
I thought I had seen my last steam system back in New Hampshire when I owned a plumbing and heating business. Fast forward about thirty years (and a fading memory) and I am once again surrounded by 20 plus steam boilers. Here is the question:
To feed or not to feed? Are chemical feeders worthwhile, recommended or necessary?
It Depends....
The necessity of a chemical treatment program is largely dependent on the application. What are these boilers used for. Generally speaking, cast iron boilers used for heating only applications where there is little or no makeup water usually do not need a chemical treatment program.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Rhomar Water
Hi- This might be a useful source for you. http://www.rhomarwater.com/ You might want to contact them with your questions. They are very helpful and good people to work with.
- Rod0 -
insurance
is what it is. backed by science. My three 650 hp boilers recieve chemical water treatment and pipe internals are immaculate. treatment company takes credit for that. we just demolished a building my company bought less than a quarter mile away that had two 1970's vintage Kewanees that never had treatment and were still functional. 40+ yrs old and running without issues. would my boss consider not treating boiler water? No way! It is insurance.0 -
what's worse?
I've seen more disasters from chemical treatment than from untreated feed. Water treatment companies always have an excuse. I recommend measuring makeup and degassing. Using hot water for makeup is inexpensive.0
