fuel oil pumps
Bryan_16
Member Posts: 262
in Oil Heating
Anyone know where I can find a replacement fot a Sundstrand #H2CB 100 4? Suntec website says they are obsolete and none of my local wholesalers can cross it.
try Sids
sounds like a 2 stage 3450 J pump? What is this on? GPH? More info would help to cross reference to another pump. Sid Harvey still remans them0 -
H & J Pumps
Its a 3450 RPM two stage pump at 16 GPH at 100# pressure, obsolete strainer, Etc.
Sid Harvey has the pump. You give them the old one so they can rebuild it and sell it to someone else.0 -
oil pump
It is a 2-stage pump rated for 3gph @ 1725rpm & 16gph @ 3450rpm.
I believe the "C" calls for a 3gph strainer.0 -
"H" Pumps:
The "C" stands for an obsolete pump strainer, to be used either a 10 GPH metal strainer or a 7 GPH plastic strainer.
If it's driven by a 1725 RPM motor and it is a burner and not a lift pump, replace the burner. It needs to go for a long rest.0 -
TIme for a burner
When ever I see "Not available" I don't do much more looking than Johnstone, Sids, RE mikes, and Webb, them 4 don't have it, then its time for a new burner... Some of them old pumps cost as much as a replacement Burner..
Always keep your takeout burners, I sell refurbed {in house} Burners {any current models afg's carlin ez's, and Riello 35's and 40's}... I have a bench and a bunch of shelves in my shop just for refubing burners, I even made a test firebox.... Pull them completely apart, paint the body, install all tested parts, and toss it on the shelf.... Last year I sold over 20 of them!!! Not too bad for stuff I would have tossed out, and I only have the guys do them when its slow in service....0
- 120 Geothermal
- 394 Solar
