Air lock
URISteve
URISteve Member Posts: 2
I currently have a contractor with a strange little problem that appears to be an air lock on the inlet side of the pump on a hot water system.  There are 2 air eliminators on this system, both a good 6 to 7 feet away from the pump and around a few elbows.  The pump is on the return side of the boiler and has isolation/check flange mounting.  And there doesn't appear to be any leaks in the closed loop primary/secondary system.
This only occurs about once a week and keeps the system from running.  I told the contractor I would go to the job and look at it with him this morning while it is currently locked up.
I'm at somewhat of a loss.  Any Ideas?
    Jamie Hall Member Posts: 26,838
    No ideas, but a question...
    Where is the expansion tank in relation to the inlet to the pump?  It should be as close as feasible to the INLET of the pump...
  • pipeking
    pipeking Member Posts: 252
    NEED SOME PICS
      to see whats going on. is the pump mounted in the mfr. recomended configuraton. how do we know the pump is air bound
  • URISteve
    Expansion tank
    Expansion tank is just around an elbow about 6 ft in front of the pump, mounted to the bottom of the air eliminator.  System has been up and running for close to 10 years without any problems till now.
  • RJ_4
    RJ_4 Member Posts: 484
    Air
    Are there automatic air vents on top of air seperators, if so they could be drawing air into system especially if your n.p.s.p ( net possitive suction press, ) at your pump goes below 0 psig.  I recommend all air vents on hydronic systems be valved off after initial fill and bleed.   pictures would be good
    OK -- next question
    as RJ notes, if the net positive suction pressure at your pump inlet -- or at any of the air eliminators -- drops below 0 psig, you are surely going to have a problem.  So the question is: what is the pressure at the expansion tank and the pump inlet when the pump is running?
