underground condensate leak repair - radiator hose
elfie
Member Posts: 266
had some trouble finding a solution to an underground pipe leak.
here is an idea - just installed a flexible radiator hose that seems to be working.
any thoughts on how long this will last? linear expansion possible?
good idea?
thanks
good idea?
thanks
Weird
I swear there was a post almost identical to this one with even the same kind of picture a year ago. Maybe I'm mistaken but I recall it not going over too well.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Yeah
I remember this one.0 -
yes same one
yes, it is the same but it is a different solution.
underground condensate pipe leaks are a huge challenge.
this solution may be very workable, but I am curious about the long term outlook.0 -
How Long
Maybe it will long enough so that you can make the proper repair which is to dig up the entire line and replace.0 -
Different Hose
I have trouble seeing it as a long term solution, but then it has been a while and you still have a hose there. So, if it walks like a duck, and talks like a duck.........0 -
replace entire line?
the pipe insert is at the point where the pipe makes a 90 degree turn.
why would you want to dig up the floor? the issue is how to deal with expansion and contraction at this point in the line.
it is virtually impossible to perfectly align the pipes (and keep them alligned), so installing a slidable expansion joint will not work
we did consider a flexible/vibration related pipe with a u-shape in this area (1 inch 1/4), and may ultimately try it if this idea does not work - it seems to be a simple cheap solution.0 -
pro press?
has anyone tried the steel pro press fitting? u think those would work?0 -
Not in my basement
I would never put that on my system.
However, that said I will admit back around 1978 my dad had a hose blowout on a pool pump and decided to used a radiator hose just like the one you have there. That hose was in use between the pump and filter for 30 years without a failure. Exposed to chlorine obviously as well as sunlight. I believe the hose is actually still on a pump in his basement but the pool is long gone.
Of course, you know, it was just a pool and the worst thing that could have happened is a burned out pump due to no water. Boilers on the other hand, between flooded basements and death are a different story.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Replace
What makes you think the rest of the pipe is in any better shape. The best thing to do is dig up the entire pipe and replace with copper.
www.gwgillplumbingandheating.com/webapp/GetPage?pid=6090 -
Replace
The more I think about this, the more it seems like a perfect candidate for polypropylene pipe (Aquatherm/Climatherm.) Welded joints, good for 250F temps, completely noncorrosive and nonreactive with pretty much anything, and freeze tolerant.0
