Trimax / DHW question
adambuild
adambuild Member Posts: 422
I have a job with a TT 110 with Trimax control and a Smart 40 indirect. I'd like to install the optional sensor in the indirect and remove the aquastat but I have a challenge. The homeowner wants to remotely control the indirect with a pair of dry contacts. I used to just interrupt the aquastat for that purpose but suspect that interrupting the optional sensor will cause a lockout. I'd rather use the sensor because it gives more accurate control of the indirect temperature. Any ideas?
Thanks, Adam
  • SWEI
    SWEI Member Posts: 7,348
    remotely control what?
    What is the homeowner trying to accomplish?
  • kcopp
    kcopp Member Posts: 4,629
    Its either or...
    not both. Does he want to put it on a timer? If he is concerned about stand by loos there isn't much... be sides letting the water drop to lower temps in a tank for long periods of time a lot invites legionella
  • unclejohn
    unclejohn Member Posts: 1,833
    This will work
    Disable the domestic hot water priority on the controller and then break the hot leg of the dhw circ. through your dry contacts.
  • adambuild
    It's a vacation house. He can already turn the heat up and down with a new Honeywell Wifi stat we put in and he wants to be able to remotely control the indirect as well. He lends the house out a lot and wants to be able to shut down the indirect if no one will be using the house for a few weeks.
    Thanks, Adam
  • Zman
    Zman Member Posts: 7,611
    Not the best...
    Disabling the DHW circ will not make the call go away. The boiler will still try to heat the tank.
    I think you would be better off with your original plan without the sensor.
    Tekmar does a nice job with this. You can put the entire system including t-stats in an away mode.
    Given the low heat loss in the smart tank, I would be inclined to leave it on. Be sure to insulate the pipes and provide heat traps on the lines to prevent migration.
    Carl
    Albert Einstein
  • unclejohn
    Ok try this
    Find out from TT what resister you need to make the boiler think the tank is 140*F and switch from resister to sensor with a 4 pole relay.
  • SWEI
    resistor
    A 3.3kΩ resistor and a set of SPDT contacts will do the trick.
  • adambuild
    Thank you Uncle John and SWEI, just what I was looking for!!! Thank you to the others as well for the valuable input!!!
    Adam
