Steel pipe BTU output
STEAM DOCTOR
Member Posts: 2,107
Does anyone have the ratings for BTU output for insulated 3" steel pipe? Thank you
R Value?
That would depend on the R value of the insulation, the average water temp and the ambient temp..Bob Boan
steam
Steam heating(212-215). 1" fiberglass insulation. unheated basement so lets assume about 55 degrees.0 -
Just figure it as heat loss
Area is d (in feet) * 3.14 * L (in feet), u-value is what it is (depends on the insulation) and temp difference is 160 F. With R-3, roughly 40 BTU/hr-ft. One man's heat gain is another man's heat loss. :-)0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
