GB142 Question
Hello All,
I just had a service call on a GB142/24, it was a 2F code which is switch related.
The boiler had 10PSI, I raised the pressure system turned on, ran though a couple of cycles working fine.
Looking though the manual for guidance I noticed it could have been a safety switch problem. My question is what is the safety switch and what does it do? It is not pressure or hi or low temps.
Thanks,
Thanks,
Pressure or Flow
2F code is a flow or pressure issue. Boiler psi must be 15psi min. on boiler display. If that's okay, then look for a flow problem through the boiler.Bob Boan
Buderus
Ironman,
Thanks for the reply, it was a pressure problem. I was just wondering what that safety switch is for, its not a limit or pressure. What safety feature does it do?
thanks0 -
Safety Sensor
The 2F issue is generally flow related. and 2E is a pressure issue.
The safety sensor you are referring to is essentially a high limit sensor. It is monitoring water temperature in the heat exchanger. It will shut the boiler down if the water temperature is too high, if the water temp rises to fast, etc.0 -
Buderus
Thanks for the answer0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
