can i use a aquastat l8148e in place of...
dereck
Member Posts: 1
My aquastat l8148a shorted out last night, the blue wire that goes into the board under the relay swich burnt up and off the board. Can I replace that with the aquastat l8148e? And what would cause it to do that?
Any help would be great,
Thank you
Dereck
Thank you
Dereck
The L8148A is
a relay with a 120 volt burner circuit. The L8148E has a 24 volt burner circuit so it can not be used to replace the L8124A.0 -
You're a good man, Tim.
And always a source of excellent, valuable information. I learn so much from you!
Alan8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Thanks Alan
always glad to help out.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
