Old gas valve
greg c
Member Posts: 14
Hi,I'm looking for a replacement for a W-R 36C61 gas valve.It is from a Raytec shop heater.I emailed W-R now Emerson and they couldn't help me.It has a 24 volt solenoid and a pilot tube and nothing else.Any ideas of what I can use to replace this?
Thanks,Greg
Thanks,Greg
Does the valve have
a thermocouple attached to the valve? If so it is a 24 volt standing pilot gas valve and can be replaced by a Honeywell series VR8300A-4516.0 -
thermocouple
Sorry,yes there is a thermocouple.I'll look at the valve you suggested.Thanks0 -
Replaced bad gas valve (solenoid coil was bad)with new Honeywell unit as advised on here.I'm nice and warm now0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
