Munchkin M80
Jasi
Member Posts: 1
How do I make sure that the condensate line in the Munchkin M80 is clean. I know that I can access the line from outside but I feel that it would be hard to make sure that the inside of the chamber is clean.
How does so much water get inside the heating chamber. When my boiler stopped working, I drained out about a gallon of water from the heating chamber.
Your help will be appreciated.
Jasi
Jasi
You need a qualified service tech...
IF you figure out how to clear the drain, it will only be a temporary fix. You need to get a qualified service technician in there to perform a full fire side service. Your warranty REQUIRES annual service on the fire side.
You are messing with something that can kill you (carbon monoxide)...
ME0
