Munchkin M80
Jasi
Member Posts: 1
How do I make sure that the condensate line in the Munchkin M80 is clean. I know that I can access the line from outside but I feel that it would be hard to make sure that the inside of the chamber is clean.
How does so much water get inside the heating chamber. When my boiler stopped working, I drained out about a gallon of water from the heating chamber.
Your help will be appreciated.
Jasi
Jasi
You need a qualified service tech...
IF you figure out how to clear the drain, it will only be a temporary fix. You need to get a qualified service technician in there to perform a full fire side service. Your warranty REQUIRES annual service on the fire side.
You are messing with something that can kill you (carbon monoxide)...
MEIt's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.0
- 84.3K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3K Oil Heating
- 57 Pipe Deterioration
- 797 Plumbing
- 5.4K Radiant Heating
- 371 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
