Attic insulation ?
robnewo2
Member Posts: 2
A question. We have an older home(1940) and the attic floor has a cellulose insulation with tongue and groove softwood flooring end to end. Very tight. Recently we had tree damage and a section of the attic floor(about 1/6) and room below was destroyed(How we found about existing insulation.) Now we are rebuilding and faced with the question...Do we build a platform over the existing attic floor to add insulation to bring us to R38? or Do we rely on the integrity of existing floor and platform only the damaged section to add additional R value to that area? or...Do we just keep the floor a single level throughout and sacrifice/only put what would amount to R18 only in that damaged area. All the walls and ceilings in the house are thick plaster almost/about 1". I'm hesitant to outlay the additional $ to what appears to be a tight existing area. Any advice? We are also going to be adding central air with all that in the attic.
What climate?
What climate are you in? Are you running heating and cooling ducts in an unconditioned space?
Albert Einstein0 -
Building Science Article
You may find this article interesting: http://www.buildingscience.com/documents/reports/rr-1205-attic-or-roof-evaluation-two-advanced-weatherization-packages/view0 -
attic ?
We are in the philadelphia area. We have hot water heat(radiators) and ductwork for AC (to be installed) will be running in attic, so that would be unconditioned.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
