COVERING ASBESTOS
RL102
Member Posts: 1
In Dan's book, he says that if there is asbestos insulation on the steam pipes and it is in pretty good shape, just cover it with plastic and it should be OK. Question, cover it with what kind of plastic? First, wrap it in some kind of plastic and tape the plastic or use some kind of plastic tape or ??????
Thanks,
RL102
Thanks,
RL102
Coverup
Why not use latex paint on it, assuming it's in good shape. That should do a reasonable job of sealing it.
3PSI gauge0 -
Why the heck
would you cover it in plastic? yuke, puke, how about childers mastic and cheescloth scrim.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 120.3K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
