COVERING ASBESTOS
RL102
Member Posts: 1
In Dan's book, he says that if there is asbestos insulation on the steam pipes and it is in pretty good shape, just cover it with plastic and it should be OK. Question, cover it with what kind of plastic? First, wrap it in some kind of plastic and tape the plastic or use some kind of plastic tape or ??????
Thanks,
RL102
Thanks,
RL102
Coverup
Why not use latex paint on it, assuming it's in good shape. That should do a reasonable job of sealing it.
3PSI gauge0 -
Why the heck
would you cover it in plastic? yuke, puke, how about childers mastic and cheescloth scrim.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
