Grundfos Magna - which mode?
Matt_67
Member Posts: 193
I just installed a grundfos magna on a cast iron radiator system with TRV's and outdoor reset. I am just curious what mode others have used in in this situation and with what results. The other times I've used the magna were on apartment buildings with zone valves - I left it in the auto-adapt mode and it worked fine.
Which
Model? The modes are clearly spelled out in the manual dependent on system type and head requirements. For instance a 65-120 would be run in the proportional mode if the head is higher then 13'.."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0 -
grundfos 40-120
It is a 40-120. The system has some long marginally sized pipe runs to the furthest radiators. I left the pump in the proportional pressure mode as per the manual. I guess I'm just trying to understand why that would be better in my situation. Constant pressure makes more sense to me.0
- 81.2K THE MAIN WALL
- 2.5K A-C, Heat Pumps & Refrigeration
- 37 Biomass
- 394 Carbon Monoxide Awareness
- 2.7K Controls
- 1.4K Domestic Hot Water
- 3.8K Gas Heating
- 101 Geothermal
- 133 Indoor-Air Quality
- 2.4K Oil Heating
- 32 Pipe Deterioration
- 579 Plumbing
- 4.3K Radiant Heating
- 334 Solar
- 12.3K Strictly Steam
- 38 Water Quality
- 11 Industry Classes
- 8 Recall Announcements
