Grundfos Magna - which mode?
Matt_67
Member Posts: 287
I just installed a grundfos magna on a cast iron radiator system with TRV's and outdoor reset. I am just curious what mode others have used in in this situation and with what results. The other times I've used the magna were on apartment buildings with zone valves - I left it in the auto-adapt mode and it worked fine.
Which
Model? The modes are clearly spelled out in the manual dependent on system type and head requirements. For instance a 65-120 would be run in the proportional mode if the head is higher then 13'..There was an error rendering this rich post.
grundfos 40-120
It is a 40-120. The system has some long marginally sized pipe runs to the furthest radiators. I left the pump in the proportional pressure mode as per the manual. I guess I'm just trying to understand why that would be better in my situation. Constant pressure makes more sense to me.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
