When there is not much else to do......
Dave in QCA
Member Posts: 1,777
We move radiators!
A building downtown is undergoing remodelling and removing their radiators. We had a chance to save them from the scap heap and so we moved 7 radiators this afternoon.
All were large tube type radiators from the 1930s. Of the 37" tall variety, we moved 2 that were 6 tubes x 18 sections (540 lbs each), 2 that were 6 tubes by 7 sections, 1 that was 4 tubes x 14 sections, and in the shorty style 20" tall, we moved 1 that was 7 tubes x 20 sections and another that was 7 tubes x 22 sections.
What a Blast! We really know how to have a good time!
Dave in Quad Cities, America
http://grandviewdavenport.com
You guys
are having way too much fun!All Steamed Up, Inc.
Consulting0 -
Pumping a little iron?
That's what I call heavy metal.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
- 120.3K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
