When there is not much else to do......
Dave in QCA
Member Posts: 1,785
We move radiators!
A building downtown is undergoing remodelling and removing their radiators. We had a chance to save them from the scap heap and so we moved 7 radiators this afternoon.
All were large tube type radiators from the 1930s. Of the 37" tall variety, we moved 2 that were 6 tubes x 18 sections (540 lbs each), 2 that were 6 tubes by 7 sections, 1 that was 4 tubes x 14 sections, and in the shorty style 20" tall, we moved 1 that was 7 tubes x 20 sections and another that was 7 tubes x 22 sections.
What a Blast! We really know how to have a good time!
Dave in Quad Cities, America
http://grandviewdavenport.com
You guys
are having way too much fun!All Steamed Up, Inc.
Consulting0 -
Pumping a little iron?
That's what I call heavy metal.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
