got a little more done this weekend. wife still mad.....
see pics.  before/after.  comments and criticism welcome.
    Steamhead Member Posts: 18,209
    With such nice piping work
    why is your wife mad?
    Consulting
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    She'll get over it
    When the house is warm and toasty.
    She may not appreciate the artistic beauty of the piping work you have been doing, but I do!
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • TomM
    TomM Posts: 233
    thanks guys
    thanks guys!
    i decided to go all out and use 30" risers.  I was disappointed that the boiler tappings were tapped slightly out of parallel, which made for some necessary finesse to get everything lined up and square.  I made sure all the USA fittings are in the front, and all the import fittings are in the back.  :-)
    I was suprised how everything came together pretty easy with proper planning.  I only needed one custom threaded length, the pipe connecting the two risers.  I could have probably done it with a stock fitting though.
    Having a machining background, i'm used to everything lining up exactly perfect.  Not so with pipe.  It takes a cool hand to get everything right.  and plenty of unions helps too.  It's modular.
    My goal is to maximize floorspace, and have everything in the most compact configuration possible.  With 4 kids, all i got left is the basement.
     Piping ain't easy!
  • gerry gill
    gerry gill Member Posts: 3,083
    Wife shouldn't be mad!
    She should be celebrating thanksgiving...giving you thanks for supplying her with a much better boiler install...looks great!
    gwgillplumbingandheating.com
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    I can keep her busy for you.
    Oops. I better not say that to a guy with a big ol' pipe in his hand!
  • Dave in QCA
    Uhhhhhhh ---- No
    Well Hap, you just made a set up for about a half a dozen one liners, but I'm gonna resist!  I don't wanna be banned from HH.com!  ha!
