got a little more done this weekend. wife still mad.....
TomM
see pics. before/after. comments and criticism welcome.
beautiful Conshohocken PA
With such nice piping work
why is your wife mad?All Steamed Up, Inc.
Consulting0 -
She'll get over it
When the house is warm and toasty.
She may not appreciate the artistic beauty of the piping work you have been doing, but I do!Dave in Quad Cities, America
http://grandviewdavenport.com0 -
thanks guys
thanks guys!
i decided to go all out and use 30" risers. I was disappointed that the boiler tappings were tapped slightly out of parallel, which made for some necessary finesse to get everything lined up and square. I made sure all the USA fittings are in the front, and all the import fittings are in the back. :-)
I was suprised how everything came together pretty easy with proper planning. I only needed one custom threaded length, the pipe connecting the two risers. I could have probably done it with a stock fitting though.
Having a machining background, i'm used to everything lining up exactly perfect. Not so with pipe. It takes a cool hand to get everything right. and plenty of unions helps too. It's modular.
My goal is to maximize floorspace, and have everything in the most compact configuration possible. With 4 kids, all i got left is the basement.
Piping ain't easy!beautiful Conshohocken PA0 -
Wife shouldn't be mad!
She should be celebrating thanksgiving...giving you thanks for supplying her with a much better boiler install...looks great!gwgillplumbingandheating.com
I can keep her busy for you.
Oops. I better not say that to a guy with a big ol' pipe in his hand!Just another DIYer | King of Prussia, PA
Uhhhhhhh ---- No
Well Hap, you just made a set up for about a half a dozen one liners, but I'm gonna resist! I don't wanna be banned from HH.com! ha!Dave in Quad Cities, America
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
