Mold Inspection Protocol
Hello Friends,
Mold inspection protocol is a detailed document indicating an exact plan of how to perform mold inspection, testing and removal in a particular real estate property. Inspection involves a careful and thorough investigation of where the mold resides in a property and deciding the safest and most efficient manner in removing it.
<strong>Killing the Mold</strong>
Killing every spec of mold after containing it to a certain area can be performed by using tea tree oil, grapefruit seed extract or vinegar.
<strong>Removal</strong>
Remove the dead mold, making sure that no left over mold is remaining in the infected area.
<strong>Protection</strong>
After the mold is removed, careful precautionary steps should be taken to prevent new mold from growing. A humidifier is a viable option.
Thanks and Regards,
Alex Johns
Thanks and Regards,
Alex Johns
The document?
Sounds interesting. How do we get the protocol document?
Was humidifying a typo? I am under the impression mold likes moisture.
Welcome to the wall.
Albert Einstein0
