Mixing demand
Handygil
Member Posts: 12
Why does my mixing demand keep clicking on and off? Everything seems to be working fine upstairs. Like when the heat needs to click on it does and when it gets to a set temp it shuts it off. Nut the mixing demand signal keeps turning one for a second then turns off.
A little more?
It sounds like you have a powered valve that is a little sensitive. Do you have a brand name or a picture?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
