Need help with rad valve never saw this one before
relymech
Member Posts: 2
any help would be great thanks see attached picture. Yeah the invisible valve I can really say I never saw it before HAHA.
I hope you can see this one any help would be great.
We Haven't Either...
Your pic didn't post.Bob Boan
Yep
Those invisible valves can be really challenging.0 -
honeywell unique raditor valve
That there is a honeywell unique raditor valve .These where installed on gravity hot water system .Take care when relocating the raditor and do not reduce the piping if you do relocate.When converting from gravity circulation to pumped be sure not to oversize your pump or you will have issues with system balance.I personally have only worked on 2 of these types of systems and have only seen maybe 4 or 5 of them in close to 30 years out in the field .Good luck and handle that valve with some special care it would be a hard search for a replacement but i do belilieve overtroupe makes a simalar type of valve for use in europe i would guess for raditors with one tapping there valve uses a inserted dip tube pretty neat stuff peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
This is the first for me and I thought I had seen it all. I had a feeling that would require a tube to be inserted in Rad. The homeowner took it upon himself to take one out and ruined it. System was converted to circulation many years age. Looks like it my be time to modernize this system.0 -
The Library
has the patent for it. Here 'tis:
http://www.heatinghelp.com/files/articles/1213/140.pdf
Also, scroll a bit here and you'll see my take on it:
http://www.heatinghelp.com/article/332/Gravity-Hot-Water-Heating/72/Gravity-Hot-Water-Heating-FAQ
Nice find!Retired and loving it.0
